Using Oil?
Smoking when I get it on it pretty bad doesnt matter what RPM especially in Neutral revving, what does that mean most likely rings?
Oil consumption happens with most internal combustion engines. But each individual engine is different. If the LS1 had any major issues it would not have been in produciton since 1997.
I know you are looking at buying an LS1, but seriously just because they blow a it of oil back thru the PCV system are you not going to buy one based off a poll where the results are less than scetchy.
I start my car I drive my car and I have fun in my car. If it needs oil when I check it I simply add some.
PCV sucking oil doesnt matter to me. I dont want a car blowing it out past the rings and I heard the low-tension oil rings gave issues in this car. If all these problems are just PCV related, I dont care. The motor is still tight if thats the case.
If I understand right, 99% of all LS1 oil usage is due to the PCV system and NOT rings/valves?
What is this I hear of new ring design sometime in 01-02???
Here is the oil-use for 4.6L GT's that I did on a mustang forum, so far as of NOW! 18% of the GT owners report over 1qt oil loss over 3K miles as opposed to 22% of the LS1 owners in the poll above that is now closed.
