General LSX Automobile Discussion Non-technical LSX related topics.
My sh*t got broken into...
Old 09-24-2006, 10:43 PM
g-ryde1's Avatar
Originally Posted by Trust
He meant it was a little more difficult to get in the car with the keys locked in it. It wasn't a suggestion to leave em'. Took me a second to get it!
my bad. yep that does make it a bit difficult, been there once or twice. two hours for a tow truck
Old 09-25-2006, 02:38 PM
Dal1as's Avatar
Originally Posted by Charging TA
Unlock button doesnt work after a short period of the car being shut off... Slimjim I understand, and using a rod to move the slider too.
Whoops, you're right. I checked last night. Although I was able to use a broom handle to move the slider too. Just took a minute longer. If you put it through the side and not the top you can get the tip of the broom right by the slider. I think I'm going to take mine out or something.
Old 09-25-2006, 02:45 PM
MrDude_1's Avatar
heh, if you really want to know how simple it can be.....
all you need is your bare hands.
grab the top of the glass with both hands, and pull back... then hold it out and stick your arm in there.
the felt strip bars that are in the door will move, and it may not seal nice unless you re-adjust the glass, but you can pull it back that far and just reach in with your arm.
works on 3rd and 4thgens...
Old 09-26-2006, 12:35 PM
DrewSG's Avatar
When does the alarm disable the unlock button from the inside?
Few months ago I left the car running with the door lock and got inside within 10 seconds. I was relieved at first then it set in how vunerable the car is.
