need a part number? (LSX-related vehicles only)
I've replaced the driver side low beam headlight twice in the past month and it's out again. I pulled the socket off from behind the light and it's partially melted inside the sockets to slide onto the light.
I need to order that socket asap. Do you have that part number for an 01TA?
Thanks!
Thanks!
The part # for a 98-02 Firebird, the wire harness/connector to the headlights/headlight motor, my friend broke off one of the tabs on the the inside of one when trying to clean out all the corrosion in mine.
Need this part number as asked below, anyone?
"I've replaced the driver side low beam headlight twice in the past month and it's out again. I pulled the socket off from behind the light and it's partially melted inside the sockets to slide onto the light.
Thanks!"
Thanks!"
#32
Banned Scammer
Need to get a few things to help tighten up the loose ends...
I need this pop rivet on the driverside door
![](http://i971.photobucket.com/albums/ae192/BashamWS6/4c920b95.jpg)
I need the tubing that goes from the block to the to TB
![](http://i971.photobucket.com/albums/ae192/BashamWS6/140eb054.jpg)
And i need this screw forthe top sensor on the driver side of the TB
![](http://i971.photobucket.com/albums/ae192/BashamWS6/8533cb62.jpg)
(blurry pic but you get the idea)
Thanks for the help
Thanks for the help
#33
Not sure about the TB screw, but for the first picture of the rivet I would pop the other one out and check local auto parts stores. They usually have sections of plastic pieces like that. Or if you go to the dealership they can pull up a diagram with the part number. And for the hose its just standard heater hose, So I would just get some from a local parts store (they sell it by the foot). But honestly I would just cap it off because its not necessary, and alot of people actually take that hose off as a free mod (called the TB bypass mod)
#37
I need the part numbers and see if the throttle cables for a 02 ss auto are available. The car has traction control and I need the cable from the pedal out
#39
I appreciate this! I would like the pn of the small, two-bolt cover just above the oil filter on some LS engines that has a drilled and tapped boss, please.
Thanks, in advance!!!
Addendum: As I understand it, the part I asked about just above is no longer available from the General. So, let me ask for a couple more, please...
The numbers for the Vette version LS3 main front belt idler and tensioner, both, please? Thanks, again.
