High Mile LS1's
#61
Originally Posted by crafty888
Cant remember where I read it, but I read somewhere that when BMW first entered a turbo in the F1 in the early 80's they had problems in the first year with blocks cracking... the next year they bought a load of second hand high mileage engines and used those as with constant start-stop-start they'd been stress relieved...... that was the first year they won F1 with a turbo
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
#62
A properly cared for LS1 should last very very long. And give you tons of power. The best thing about the LS1 is that it will let you know that something is wrong. It usually isnt the type of motor to brake something under normal driving conditions. And besides, you could build a budget stroker motor, or a forged 347 for less than a new stock LS1.
#64
Originally Posted by TWS
yep. They concluded they had to do build-ups on "seasoned blocks". That's the term engine builders use rather than just calling it a "used block". ![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
