General LSX Automobile Discussion Non-technical LSX related topics.
Basic Tune or Dyno Tune, that is the question.
Old Oct 21, 2006 | 10:25 PM
ryle's Avatar
Default Basic Tune or Dyno Tune, that is the question.
I'm going the be having my car tuned in the spring. Can't decied whether to do just a basic tune or a Dyno Tune.
My car is going to have SLP Lid, Ported TB, LS6 Intake, Pacesetter LT's, 3400 Stall W/ lockup, 3.73 gear (changing from 2.73)
Is it worth it to Dyno tune??
What kind of gains basic/dyno
Old Oct 21, 2006 | 10:47 PM
2002t/a06's Avatar
yea i would do the dyno tune.
________________________
02 t/a a4. 6.0l iron, comp cam, mac mids, borla, lid.
Old Oct 21, 2006 | 11:35 PM
BrandonDrecksage's Avatar
wha tthe hell is a basic tune? A handheld? or street tuning with hp tuners or efi live? Or is it a basic tune..basic meaning n/a car as opposed to a f.i. car?
Old Oct 22, 2006 | 12:21 AM
BayAreaSS's Avatar
The dyno tune will be worth it
Old Oct 22, 2006 | 12:50 AM
ryle's Avatar
at the shop i was gonna have the tune done at, they do what is called a "basic tune" set's new shift points, adjust's A/F and removes some trouble codes and some other things as well.. Obviously a dyno tune is a little more thorough and costs more.
Old Oct 22, 2006 | 01:18 AM
ryle's Avatar
Speed Inc
PCM Tuning
LS1/LT1 "Basic tune" Includes the following enhancements
-desired fan activation temp (for low temp t-stats)
-Torque management removal (a must for LS1 automatic cars with aftermarket converter)
-Rear O2 sensor codes deleted (for cat-delete cars)
-Speedo calibration (for gear and tire height changes)
-Desired idle speed (for "lopey" cams)
-Skip shift function delete
-Shift points optimized
-Injector size changes
Old Oct 22, 2006 | 03:58 AM
DaGeneral's Avatar
Dyno Tune. No doubt about it for me. Some guys will say you dont need a dyno to tune the car...
I saw 18 HP and 27 ft/lbs of torque from my dyno tune. Mods in sig.
Old Oct 22, 2006 | 06:31 AM
darrensls1's Avatar
I would definately go with a dyno tune since you have LT headers. A lot of people run lean after a LT header install which will rob some HP. If you get the dyno tune they will adjust the A/F and probably gain you anywhere from an extra 10-25 rwhp depending on how far off it is.
I gained 29 rwhp but I was an extreme case. New Era Performance told me that my car was running so lean that the motor was at serious risk had I kept driving it like that
Old Oct 22, 2006 | 06:42 AM
not lean, rich, the leaner you go, the more power you'll make till you hit knock or melt a piston.
Old Oct 22, 2006 | 07:09 AM
darrensls1's Avatar
Some go rich and some go lean. Mine was lean. Ask Mike @ New Era. It was so lean I was losing alot of HP. 29 rwhp to be exact.
Old Oct 22, 2006 | 07:56 AM
Splitz's Avatar
I got 339HP after mods in sig. He did a quick dyno before mod's said it was @ 300HP.
Old Oct 22, 2006 | 07:58 AM
Shallow Bay's Avatar
Buy a full tuning suite (EFI Live, HP Tuners) with a wideband and tune it yourself.
