A little ABS Inop/ASR Lights help
Well it's not really a big issue to me right now, but I'd like to fix it. I have no asr nor abs. I've pressed in the connector to the sensor in the rear above the axle, checked the fuses under the hood and now getting on here and asking. What else can cause those lights and the asr/abs not to work? My car's been this way since I got it. Right now it's my daily driver and asr would be a little nice I think on those heavy rain days.
Do you have stock gear ratios, differential, tire size? I was having the same problem since I have taller gear in the diff. After adjusting the wheel size with my Predator tuner it went away after a couple minutes of driving. Although, the ABS INOP light still comes on if I brake/ downshift really hard.
You need to get the car on a scanner to see what exactly what's going on with it. You can't just look at it physically and see if a sensor is bad or if the ABS motor went out.
I have the stock gear, rear end, and tire size.
LS1Tech Administrator
Received 1,792 Likes
My guess is a bad wheel speed sensor. Been there, done that. Same symptoms as yours. Not on an F-body though.....
