Why is GC 0-30 so "watery"
Originally Posted by BLKWS.6
Yep, didnt have to look too far, have to replace both axle bearings now. These cars are pretty maintenance intensive! I didn't know what I was getting into I dont think when I got one, lol. Oh well, when you go fast, stuff wears out quick
Just think about what you were planning to do had you not fixed the stalling issue.... remember? Trade it in. Then someone else would be fixing it. That's just the luck of the draw with used cars man; any make, any model can be afflicted. Even certified used.
Everyone is misunderstanding I'm not worried about it, just curious WHY! The mobile 1 cools the same amount...
BLKWS6....everything will be ok! I was almost the same with my GTP when I first got it, make everything perfect so I dont have to worry about it later(and a lot of "what was that noise", "is that normal", etc) and now buddy, after almost 3 years ownership and 80k mi....I really dont care about it, it gets just enough to keep it running properly and thats all....nothing more. My WS6 mind you gets treated very well(only Delco parts, kept stock), but to be honest, unless im gonna keep the car til im 90(prob will with the WS6), its getting fixed when something is about falling off or banging louder than Peter North.
I can hear it over my radio depending on how loud I crank it (loud enough to hear the **** weak speaker crackle, lol)
Originally Posted by Asmodeus
I would guess it had to do with the property that makes it slick, soit doesn't stick to anything.. including your dipstick.
Man you are soooooooo paranoid. You can't tell **** by how slippery, thin, thick, etc, an oil "looks".
If you really want to know what is going on, take a sample and send it off to be analyzed. /Thread.
I just asked a question put of curiosity. Its like you telling me im a hypochondriac because I got a physical before playing basketball in highschool. Dang
Hopefully this technology doesnt work with main bearings
#32
No, the anti-wear agents adhere to metal surfaces to prevent wear in areas prone to metal to metal contact like main bearings. Those additives are there for "boundry lubrication" where oil is squeezed out from between moving parts in high load areas. You won't see that situation on a dipstick. Don't overanalyze everything. You'll worry yourself into hating your car. I did that with my Grand National.
My dipstick is metal, lol, point taken. GC works, so I wont question it.
#33
Originally Posted by Revelation Z28
its synthetic thats why. and 0W is thin as it is so itll attack the bearings quicker.
Originally Posted by redramair98
if not mistaken wouldnt 0 be the thinnest oil u can get, and it wil thin as it gets hot
The first number is simply the oils cold viscosity number. The second number is the viscosity at operating temp. GC simply flows better at 0*c which means the oil will get through the engine more quickly when you first start the motor on a cold morning. GC is actually considerably thicker at 100*c than mobil1, and offers much better protection, as shown by countless oil analysis results. Running GC 0w30 in no way will accelerate bearing wear as compared to Mobil1 5w30 or 10w30. Infact, its exactly the opposite.
#34
The axles were dead silent 3K miles ago when I got the car. It came to light AFTER I bought it. The IAC...well maybe that was before, but the axles showed NO signes until recently.
#35
I finally took the GC 0W30 plunge!, and have to say, the car sounds slightly quieter, but feels a lil more loose(freer moving) when accelerating. Mind you I only did the oil change and took it for a quick 4 km run....i like it! now if only the summer would come again! and the oil seemed to somewhat stick to the dipstick!
#36
Overall, GC has quieted my car down, thats for sure. I like it. I just wonderd about the drippyness of it, thats all.
#38
you answered your own question:
yes, but the mobil 1 10W-30 is thicker when cool.
mobil 1 10w30 is thicker then 0w30 when cool/cold..your comparing a 0 weight oil to a 10w oil..heating then up is a different story...they now are both 30 weight and should be relitively close in weight....understood that by nature the gc is slightly a thicker 30 weight vs the M1
