NNnnoooooo!!!
...A "P1415 AIR System (Bank 1)" is what caused this to occur, it is a DTC and DTC Pending code. Help... Is this the A.I.R. Emission system? Will the dealership fix for free since I am under 80K miles? If not, what is wrong, how much? Who when what where how? Thanks guys! (PS, is driving it like this hurting anything?)
Oh...any particular cause for this thing to break, whatever it is? Is this common?
dealership will take care of it, but it just may be a leak in the AIR system, or its plugged up with carbon.
AIr is part of emissions, it runs oxygen into the exhaust before the cat(s) to help heat them up faster. it only works when the engine starts up, or reaches a certain temp.
dont use it too loosely around dealerships.
it may be the $80/hr diagnostic. plus TO fix it.
Get some non-emissions longtubes and remove all that crap. Then have the AIR turned off with a tune.
I dont mind replacing it myself if its not free for the dealer to do so, but I do want it fixed correctly. Every automotive project I have had has come off damn clean and I dont want this one to be different. Hell, I had the inspection officers thinking my car came stock with a carb on it when I had that 5.0. At least when I said "some were carbed" no eyebrows went up...werd
It is probably just a $2 air check valve which takes less than 5 mins to replace. You hung out on these boards for a long time before you bought the car, you should know not to freak out over the little common problems that they all have.
just check the AIR system out and make sure the pump is working and getting air to bank 1, then it more than likely is the check valve.
You need to think POSITIVITELY! All will be right with the world if you zen out a bit! No car is perfect!
Sorry cant help you but your problems really amuse me. Sorry bro
