Buying a totalled camaro for an ls1
Originally Posted by SSdreamz
where you from? i know of a 1999 z28 with some body damage with 45k on the clock. he wants to just get rid of it cheap
so will the Z06 drop right in ls1 cars?
TTT.. whats the diff between a z06 corvette andgine and a regular corevette engine? arn't they both ls6's and will they drop right in a 98-02 f body? and how can u tell its a Z06 by lookin at it??? sry for the long post lol im a newb
A normal C5 has an LS1 in it which is the all aluminum fuel injected 346 CI engine. A C5 Zo6 has the LS6 which is basically an LS1 but with better heads/cam. They are both the same demension wise. A regular C5 has the same engine as an F-body, just the accesories are mounted differently( PS pump, alternator, etc.) I believe the vettes also have drive-by-wire as well.
The motor will drop into an F-body no problem. Although you will need a transmission out of an F-body because vette's tranny set-ups are different. They are located in the rear of the car rather than being bolted right behind the block of the engine. You will also need F-body accesories and brackets.
