whats wrong with your car?
#62
well, i have to finish sanding the whole car, fix clutch pedal, passenger and driver window motors, the hatch doesnt open when i push the button i have to push it a few times to get it to work, shifter boot is messed up, new tire slow leak, just bought new headlight assembly and fender, front bumper still needed, still need to replace the throwout bearing, driver seat is torn from wear n tear, door hinge is kind of loose need to adjust it cant think if theres anything else
#63
The passenger side window is on its way out, I'm almost afraid to roll it down these days. There is some strange squeak coming from around the spare tire area. And it could use a new converter, intake, cam, rear end..... you know some speed parts.
#65
Needs:
Shocks
Paint on hood is flaking off
Front bumper needs paint from previous owner scraping it
Chunk of fiberglass missing from driver's side door edge, no idea how the previous owner did that
Small scratch on rear bumper from a Harley running into me.
Clip on window switch is broke
Need a new spring on the trunk
Paint bubbles on the b-pillar
Rear tires are shot
Stereo is currently a hack job from removing my amp when I tried to sell it.
Shocks
Rear tires are shot
#66
oh yeah I forgot to put that my stripes look like total *** now. After took the car cover off last spring the stripes were spidercracked and they have gotten worse. So now I'm gonna have to get a sunoco hood to replace it.
#69
Blower motor -replaced
Driver side window motor -replaced
-The previous owner curbed two of the SS ten spoke rims a bit, putting off on fixing that because I want new rims.
-Front rotors are warped a little, I just find it annoying.
-Needs Alignment
Otherwise it's been a good car for the past two years, it's not a daily driver though so I'm sure if I was putting the miles on it problems would pop up.
-Needs Alignment
#71
Need to lube window motors
Passenger window leaks around the wirror (pulled away from the window for some reason)
Need an oil change (that's no biggie)
Eaton Diff howls for no reason
Driver sun visor won't stay up
Need a headlamp
Need a foglight bulb
Rested my elbow on the console and broke the bottom part fo the pad
Keep breaking my shifter boot frame
Need the rubber boot that actually goes around the shifter to keep road grime out
Shocks squeak
Drivers side exhaust pipe fell out of the muffler (Threw it in the median and left it)
Fluid is coming from somewhere in the engine bay and getting sprayed all under my hood
Rotors need turned and new pads
Paint needs to be touched up in spots and polished
Oh yeah, TOB is whining when the engine is cold.
Need a headlamp
Shocks squeak
#72
Alright-
Clutch and hydraulics- Going in this week
Won't go into reverse- Getting fixed this week
Exhaust leaks- Getting fixed this week
Exhaust loose and rattling- Getting fixed this week
Need a tune (200-1700 rpm fluctuations at idle)- Getting fixed this week
Tires bald as can be
Drivers side window leaks
Passenger side window motor
Switch on drivers side door won't stay clipped into the door sticks up into the air exposing all the wires for the window and locks
Bracket on drivers side seat for seatbelt is broke off the seat
Chrome is chipping off the wheels
Headlights are fogged up and need replaced
Power steering pump is going
All but two speakers are blown
It's still fast going in a straight line...... I guess that makes up for the crap that's broke.
