General LSX Automobile Discussion Non-technical LSX related topics.
is it true....
Old Apr 2, 2007 | 11:25 AM
tatman's Avatar
Question is it true....
that a regular z28 ls1 (not an ss) is governed at 108mph?
Old Apr 2, 2007 | 11:34 AM
Ericbigmac83's Avatar
no, some are limited based upon which speed rated tires they get tho
Old Apr 2, 2007 | 11:38 AM
2QUIK4U's Avatar
Some of the older A4 z28's with 16" wheels and tires were speed limited but I think it was around 112mph.
Old Apr 2, 2007 | 11:39 AM
slikrider20's Avatar
I read in a car review in the z28 unless you had the z rated tires it was governed at 108....but hell my v6 3.4 is governed at 115 lol
Old Apr 2, 2007 | 11:44 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
As stated above, the only way this is true is if the car was originally optioned without the Z-rated tires.
So long as you had the Z-rated tires stock, the factory limit is set to something like 162-163mph.
Old Apr 2, 2007 | 12:41 PM
tatman's Avatar
im about to buy a 2001 ls1, what info can i provide you guys about the car im looking at to tell me if it has the z rated tires? or what do i have to look at ti see if it has it or not?
Old Apr 2, 2007 | 12:57 PM
12secSS's Avatar
The tire info should be on the driver's side door jamb. If it states Z-Rated tires, it will be limited to 160 MPH. If it does not have Z-Rated tires, it will be limited to 120 MPH.
Old Apr 2, 2007 | 01:02 PM
68Goatboy's Avatar
out of everyone here, who sees 160mph on a regular basis?
Old Apr 2, 2007 | 01:17 PM
kozak's Avatar
haha, 108, haha. but seriously some of the older z28's with a certain performance package (g32?) were governed to 120 you can tell these cars because they have a 120 mph speedo. my dad has one of these cars. it has real low rear end gears and a 120 speedo and "crappy" tires.
Old Apr 2, 2007 | 01:18 PM
Nine Ball's Avatar
LS1Tech Co-Founder
keep in mind that the speed limiters are easily removed with even a simple computer tune or by using something like the Hypertech programmer or such.
Old Apr 2, 2007 | 01:43 PM
tatman's Avatar
[QUOTE=Nine Ball]keep in mind that the speed limiters are easily removed with even a simple computer tune or by using something like the Hypertech programmer or such.[/QUOTE
thats true, its just hard to comprehend the fact that a 310hp 6 speed 5.7 liter v8 engine would stop at 108 when i did 125 with my P.O.S 4 cylinder passat
Old Apr 2, 2007 | 01:50 PM
staringback05's Avatar
like stated before it depends also on the tires....your not going to be doing that high of a speed on the non zrated tires for long...
Old Apr 2, 2007 | 04:10 PM
2000badbird's Avatar
non z rated tires will hold up to high speeds for a little while i would not trust it tho
Old Apr 2, 2007 | 04:32 PM
1meantransam's Avatar
my friends cut out at 117, mine doesnt cut out even with the programmer off
Old Apr 2, 2007 | 06:22 PM
RPM WS6's Avatar
I used to run my (non Z-rated) BFG DRs at pretty high speeds on the expressway. They did fine for short blasts, other than feeling a little loose above 110mph.
I think the speed rating will only be an issue for sustained speeds.
