any big guys have Ls1's?
Originally Posted by RPM WS6
Wow. I'm 1 inch taller than you and I'd be uncomfortable with the seat all the way back.
LS1Tech Administrator
Received 1,685 Likes
Originally Posted by BLKWS.6
I saw some kid with his seat so far back in his damn dub-mobile that his torso was turned 45* just so 1 arm could reach the wheel
5'11 255 lbs i fit just fine.. im workin on losin weight tho.. aslong as ur driving you wont have a problem..just no sitting in back seat i hate sitting in the back of an f-body...
I'm 6'5, 260 with no issues in the fbody. I think the biggest problem with 450 lbs will be getting out of such a low car. You're going to have to pull on the door or ttops to help. Also the doors are so long, if someone parks close to you it's difficult to open the door enough to get in or out. Especially as wide as 450 lbs must be.
I did some research the gto have almost 2 inches less leg room then the F body,
I am not worred about getting in and out, as long as ttop are out ill be fine
another option might be a Grand National but i kinda want to autocross
I am 6'1" and a little over 300lbs. I feel that I have lots of room in the car. Many other cars feel cramped to me after being in the Camaro. As has already been said, the door length can be an issue if you wind up in a tight parking spot.
