100,000 mile general maitence
The Z28 is slowly approaching the 100,000 mile mark, and I definetly want her around for another 100,000 miles. On my list of things to do:
1. Drain and flush coolant
2. Change oil(duh)
3. Change automatic tranny fluid, not a full flush.
4. Change serpintine belt
5. Replace rear tires. Again
I seafoamed the engine, installed an oil catchcan, and changed the sparkplugs and wires about 30,000 miles ago. I used the OEM spec A/C Delco plugs again. I'm debating on doing this again. Advice would be appriciated.
Other than the smoky burnouts, my car has a pretty easy life. 90% of the miles on it are interstate going 80mph. Car runs great BTW.
Any other general maitence items you recommend???
2. Change oil(duh)
2. Change oil(duh)
2. Change oil(duh)
Another point to consider is your wheel bearings. How are they holding up? Lastly, you might want to consider a rearend different fluid change - just be sure to put in some of the genuine GM additive if you decide to do so. Just my $0.02 for now, good luck.
