How much does a LS1 block weigh
LS1Tech Administrator
Received 1,492 Likes
Bare or assembled?
I think the bare block is 107lbs.
The LS1 block is made of 319 aluminum heat-treated to the T5 standard by the Montupet Corporation of Ontario, Canada. It is cast using the semi-permanent mold technique which Juriga described as "....a cross between die-casting and sand-casting." The case weighs 107 lb. Compared to the Gen II's 160 lb. block, that’s a significant weight saving.
blah blah blah
blah blah blah
blah blah blah
blah blah blah
