Car feels.... strange
Originally Posted by RPM WS6
I've owned 3 LS1s with the auto trans, two were 3.23 geared cars and one is a 2.73 geared car. The 3.23 cars will give a lot more wheel spin off the line when stock, but my 2.73 car breaks the tires loose from a dead stop pretty well too.
Not sure what to tell you?
The new tires are wider then stock, went from 235/45/r16's to 275/35/R18's, not much softer as far as I can tell. I have ASR and if engaged it will push back on the throttle like stated but even with it off I can't even lay 5ft of rubber. I assume my stock gearing is 2.73's maybe I need to check the rpo codes or was it even available with 3.23's? I will try cleaning up the maf tomorrow, and see about getting the fuel fitler changed at the next service. How does a guy go about cleaning the MAF? q tip and rubbing alcohol?
LS1Tech Administrator
Received 1,685 Likes
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
RPO GU2 = 2.73
RPO GU5 = 3.23
But even with 2.73s and 275 rubber, I can still get the tires to spin from a dead stop.
RPO GU5 = 3.23
Yeah, my window sticker, which I found after purchasing the car, in the manual case, reads that I have the performance axle. My current tires are much, much softer than the previous ones, the previous ones would cause ASR to slam my leg into the steering column, they had no grip whatsoever. The ZRis are nice and grippy.
To clean the MAF pick up some MAF cleaner from any parts store. Then just take the maf housing off and squirt the wires and screen real good from all directions and let it air dry. No need to touch the screen or wires with anything. Those wires are very delicate and new ones aren't cheap. Pretty simple to do, just take your time and use a little caution around those wires.
Others use q-tips and other types of cleaners. If you don't want to pay the 5 dollars for the cleaner you can try a search and see what others have had success with.
I'd be glad if I couldn't burn out when i take off from a dead stop. It feels "strange" because you aren't starting in your powerband and it has to work its way up the rpm range to make the power...i'm sure that's all there is to it.
1 Post
Spray it good. Twice. Let it dry. No touchee!
I sure don't have any problem spinning out of the hole. I have to come out like an old Gramma if I want the tires to last. They're stock size - 245's.
#33
So i was havin the same problem as you... well i think the best thing to solve this is more mods. I just added the f.t.r.a system to my 99 z28, and cleaned the maf an the car is a damn beast. I first did the maf sensor, and it was a complete difference after that, but then i put the ftra on, and that car pulls hard. I can smoke the tires with nor problem. The car is a beast... Mod more, and youll smoke the tire...
#34
Cleaned up the MAF today and got a bark outa the tires afterwards, so musta helped some, time to start saving up for some mods though, cam, headers, ect..
#37
Seafoam the hell out of it. And as stated ^^^^^^^ figure out what that tire size does to the overall ratio. I'll bet it's more than you think. Also (just curious) what tire pressure do you have? My Kumhos rate at 55psi in the rear, if I go down to 35 (where a lot of people think a tire should be) it makes a huge difference.
#38
Originally Posted by warpwr
Do you have larger diameter tires than stock?
That will make a difference.
Push the ASR button to OFF, if you have one.
That thing will never let you spin the tires. That's what it's for to prevent wheel spin on snow or wet roads.
#40
Originally Posted by slikrider20
My car has the 3.23's in it, from a dead stop you can spin the tires a block but thers def a lot more giddy up from a roll
