General LSX Automobile Discussion Non-technical LSX related topics.
Spinning
Old 07-21-2007, 05:13 PM
99Z28LS1's Avatar
buy some tires called Mickey Thompson ET Streets and that will solve all spinning issues just becareful because they cause other parts to break too
Old 07-21-2007, 10:34 PM
darrensls1's Avatar
Originally Posted by 2001BlkWS6
Im not real smart when it comes to a transmission and all.. Do you have a pic of a trans cooler u could send me so I could see if its underneath the car.
And I know it cools the transmission but whats the effects that could happen without one?
This is what one looks like:
http://www.neweraperformanceparts.co...ge/bm70264.jpg
Just get down under the front bumper of your car and look by the radiator. It'll be pretty obvious if it's there or not.
Any stall 3000+ generates more heat then a stock 4L60E transmission can handle. If you do have a 3500 stall (which it sounds like you do) then a transmission cooler is a must otherwise the transmission will likely start showing problems sooner rather then later. And at a cost of less then $100 there is no reason not to get one.
Lemme know if I can help in any other way. Good luck.
Old 07-22-2007, 01:36 AM
Arc00TA's Avatar
I can spin up to about half way thru second with my tires at 30% or so. My old tires were beyond 0% and I could spin until I let off the gas, was kind of scary because any downshift on the highway meant I was going sideways.
