Oil is it okay to use synthetic?
Right now i currently have 5w-30 in my 2000 m6 ss and i want to go to either royal purple synthetic of mobile one and i was curious if i was able to just go straight to synthetic oil or do i have to do something first?
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
LS1Tech Administrator
Received 1,726 Likes
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
If you plan to switch to synthetic, you will need to do about $4,500 worth of upgrades to the engine to prepare it for the swap. Otherwise, your enging will likely fail within 27 miles of useage with the first batch of synthetic.
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
All you need to do is drain the old oil and fill with fresh synthetic and a new filter. Simple as that.
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Use the Royal purple, or look for some German castrol 0W30 oil- it is the best oil for a ls1. A few autozones carry the oil, if you can't find it you can get it from WS6 store.
