General LSX Automobile Discussion Non-technical LSX related topics.
Automatic headlights!!!
Old Aug 5, 2007 | 09:58 AM
Mr Incredible's Avatar
Here's how I did it (see the attached photo).
Lift up the dash pad and use one of these connectors on the two wires leading to the daylight sensor in the dashtop vent grill.
It's that easy.
Old Aug 5, 2007 | 12:30 PM
Zero4488's Avatar
Restricted User
My friend has a 97 Z and he has auto headlights....
Old Aug 5, 2007 | 01:15 PM
BriancWS6's Avatar
Originally Posted by bww3588
everyone has a Canadian built F-body, ALL Camaro's have AHL's, ALL Firebirds/Trans Am's built for sale in the US do NOT have AHL's, all Firebirds/Trans Am's built forsale in Canada DO have AHL's. once again, if you have a Camaro, it doesnt matter if your car was built forsale in outerspace, your car has AHL's.
Exactly
I have had two TAs. The 01 had auto lights, and my current 02 doesnt.
Old Aug 5, 2007 | 03:24 PM
allbaugh_04's Avatar
I removed the dash panel where the stereo is. And pulled up on that black box that's directly behind the stereo. Removed the blue connector going into it and it works great.
Old Aug 5, 2007 | 03:30 PM
3stgstocker's Avatar
just cut the orange wire on the switch and tape it up like the other guy said ive done it to three cars with no problems
Old Aug 5, 2007 | 03:34 PM
Camaro396's Avatar
sweet im gonna cut the orange wire. i hate auto headlights!
Old Aug 6, 2007 | 12:53 AM
93blcZ28's Avatar
hell ya cutting the orage wire in the morn!
Old Aug 6, 2007 | 07:54 AM
Just wondering to the cut-the-orange-wire guys...
Why does it seem better to take the dash apart and cut a wire (thus making it a difficult and tedious reversal should it ever be needed) than to quickly and easily lift the dash to snap on a single connector that can be just as easily removed, as was shown in the photo above?
Curious about that thought process...
Old Aug 6, 2007 | 02:26 PM
waldershrek's Avatar
Not all cars have the sensor on the dash. My car does not as the headlights came on automatically when the key was turned foward. Some have the light sensor on the dash that turn them on when it gets dark. If you do not have the sensor on the dash cuting the wire to the light switch is the easiest way.
Old Aug 6, 2007 | 02:48 PM
Ah-so....
Old Aug 6, 2007 | 03:01 PM
SCRWS6
Guest
Posts: n/a
sometimes people just need to destroy things.....
Old Aug 6, 2007 | 04:15 PM
  #32
chevy the kid's Avatar
I live in france, i don't have the drl and auto headlight. Normally we have the parking light (white) in headlight but i have change it to move it in turn signal as yours.
The only problem is that i want my clear corner illuminate all the time...
Could you explain me how it work you drl. Maybe i have just to buy the component at the rear of stereo?
Old Aug 6, 2007 | 08:39 PM
  #33
93blcZ28's Avatar
ya i guess if you have a sensor cutting the orage wire does no good!! so guess ill try the other way
Old Aug 6, 2007 | 10:06 PM
  #34
Just remove the blue connector like a i said a few posts up. It's easily reversible too...can't go wrong.
Old Aug 7, 2007 | 12:35 AM
  #35
93blcZ28's Avatar
except if you have amanual your trunk hatch wont work read this over there are many little things that it does.........
http://www.xse.com/leres/ss/drl.html
Old Aug 7, 2007 | 12:36 AM
  #36
93blcZ28's Avatar
i jus wire nutted and taped off the wires to the sensor, works amazing! def worth the 5 min of work
Old Aug 7, 2007 | 09:05 PM
  #37
I already read it. How else did I know about it. What other little things? it doesn't say anything else...like I need to know if my brake is on anyways
I guess u guys with standards are screwed
Old Aug 31, 2007 | 11:43 AM
  #38
WhiteBird00's Avatar
Ungrounded Moderator
The misinformation in this thread is absolutely amazing!!
ALL f-bodies with automatic headlights (Camaros and Canadian Firebirds) have a sensor in the dash.
Cutting the orange wire at the headlight switch works only for Camaros. If you do that on a Firebird you will disable all of the running lights (tail lights, fog lights, marker lights).
It is always best to make electrical modifications with the least side effects and cutting of factory wires possible. The best way to make this modification is the same way that GM themselves did it for US Firebirds - they shorted the two sensor wires together so that the DRL module thinks it's daylight all the time. The easiest way to do that is with the Scotchlock connector as Mr Incredible posted. It's even easier than unplugging the DRL module (behind the radio) without any of the side effects. It's also easier (and smarter) than cutting wires.
Old Aug 31, 2007 | 06:01 PM
  #39
nrmustang's Avatar
...... once again, if you have a Camaro, it doesnt matter if your car was built forsale in outerspace, your car has AHL's........
LOL thats funny!
