engine bay clean up started
so i am in the process of pulling my motor, and while it is out i plan on doing a few things. no one can argue against me when i say that ls1 f-body engine bays look like straight
butt so i am going to clean it up some. i am doing the passenger fender wire mod, and a homemade coil relocation to under the cowl, and i am going to polish my valve covers. the other thing i am going to do is move the fuse boxes further down and move my tcs delete block too. i already moved the battery in the hatch, removed the tcs, and ditched the coolant overflow for a smaller over flow can. i'm hoping to have it all done by the end of september. post up if you have any advice or i'm just going to kind of wing it.
![Doublepuke](https://ls1tech.com/forums/images/smilies2/doublepuke.gif)
Be sure to post some pics up when you're done. I'll probably end up doing the wire mod one day. Do you have a smooth bellows? If not, it doesn't look as cheap as the stock rubber accordion style.
thanks for the ideas, i will def. look at doing those. i will take pics as the project goes. so far i dropped both fuse pannels down, and it looks much better, now i am fabbing a cover to go over the wires. i have some other ideas too.
