Exhaust rattle
Exhaust rattle
Hey I got an rattle in my exhaust that I can feel when I am driving. I vibrates my seat when I am at a stop in Drive. It goes away if I put the car in neutral or park but rattles in every other gear. Does it just need tightened or is it something else? I listened to it and it and it sounds like its coming from the Y pipe area. I'm still running the stock cats and Y pipe but had a catback put on it a couple months ago.
Location: The dirty taint of the country. ...Los Angeles
Originally Posted by y2k_ta
If it's vibrating your seat, the exhaust is touching the underside of the car somewhere.
Same thing too. It would stop when in Neutral. ...Another thing you might want to check is the exhaust hanger nearest to the tranny.
Well I found the problem. The new problem is I can't fix it. It's the band clamp where the I-pipe meets the Y-pipe. Damn nut wouldn't budge. I'm gunna take it to the shop tomorrow to get the rear end leak fixed so if they are done early enough I'm try to go to meinekee and see if they'll fix it for free since they are the ones who put the exhaust on and obviously didn't tighten it down enough.
