having problems shifting over 5800 in a six speed
i have a ram powergrip hd clutch, shifts fine under 5500 but when i race it and get on it cant shift over 5500 i can shift over 5500 but must shift very slow. seems lilke its not disengaging all the way and feels like hitting a wall for every gear when shifting fast,have stock hydralics .thanks
Please read through this section thoroughly, it is highly informative. https://ls1tech.com/forums/manual-transmission-14/
Please read through this section thoroughly, it is highly informative. https://ls1tech.com/forums/forumdisplay.php?f=14
very good read.
have you tried bleeding and doing the drill mod?
yea i bled it i had the drill mod on my old master/slave and it did the same thing but it was leaking,now i got the knew master/slave but no drill mod and not leaking and still it does the same thing do u think i should do the drill mod on the knew master/slave.since this one is not loosing fluiid pressure
