General LSX Automobile Discussion Non-technical LSX related topics.
help me diagnose this problem
Old Oct 21, 2007 | 03:24 AM
razorclaw99's Avatar
Default help me diagnose this problem
i have no idea what this can be...When i turn my key to the on, 2 things happen.
1. The security light will come in and i cant start it for like 15 attempts..
2. It will click once (starter) and thats it..few more tries and it will start up..do you think its a bad ground or my starter? I started rolling down a hill and while i was moving i turned the key and it started..its really weeird. its becoming a habit that it doesnt want to start anymore..
Old Oct 21, 2007 | 03:33 AM
capn smokey's Avatar
Could be a low tire or maybe low fuel. J/K, it is most likely a malfunctioning pcm. Does it pop any codes?
Old Oct 21, 2007 | 04:11 AM
nope..i think its bad ground..its def not the pcm
Old Oct 22, 2007 | 09:55 AM
slayerized6's Avatar
same happened to me a couple weeks ago. turns out i left the map light on and didnt know it. it would take about 15 attempts to start it too. just check your lights, connections; you never know what you might overlooked
Old Oct 22, 2007 | 10:46 AM
its turbo time's Avatar
i was having similiar problems when the bolt holding my negative battery lead was topped out into the battery. The bolt felt tight but the lead wasn't. i just grabbed a washer and popped it between the lead and the battery and now the problem is gone.
