turn on fans for HP???
hey guys i fineally did the manual fan switch mod and thermostat mod, and i wanted to know if it was a good idea if i were to keep the fans on lik when im gonna launch my car and max out the gears? would the air the fans are pulling help out my FTRA or would it mak it worse? and is it a good idea to keep it on driving on the freeway? o and also I keep the low speed fan on normal driving. thanks alot for eny help
Uh make it switch on a t 180 or so degrees on the track and 190-200 on the street and you will be fine. The fans are actualy draining hp ilbeit a small amount through the alternator when running so they should only be on when they are need GL man
