question about my car
my car is spitting oil from underneath it. sometimes it will leave a spot as big as a football, and other times it will run and not leak none. still holding about 45 on oil pressure at idle. dont think it is rear main? any suggestions please, i havent been driving my car, im itching to get back in it.
Well to start I would jack it up and see if you can see where it is coming from. Without even having an idea of where it's coming from it could be a hundred different things. How much oil are you actually down?
jack it up and clean everything up...put it back down and come check it in the morning if you arn't for sure ya know....by that time you should be able to follow a trail
yea.. clean it up real good and run it and take some pics.... could be a hundred things......... rear main seal, rear cover seal, drain plug gasket, rear oil galley plug, oil filter gasket, etc, etc.
