Is This A Good Deal? 98z fixer upper
A bad ring would cause blow by which would burn oil and cause blue smoke. Same deal with bad valve seals.
Ask if he minds if you compression test the car before you buy it.
In that case its just the coolant i suppose. No blue smoke, just a little bit of white smoke, which i think every car has when its started on a cold morning. And yea, if i cant afford this car, i will definatly let you guys have his number.
Vortech's kit is made for a bone stock motor, I doubt it damaged the motor unless it was unhealthy before the install. Also remember he had to tap the oil pan for the S/C, might want to make sure that was fixed properly.
I would stay away unless you have the cash for a new motor.
LS1Tech Administrator
Received 1,686 Likes
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I mean, I agree that we all need to look out for 'number one', but it's nice to do a little bit of good here and there. I've given people killer deals on stuff from time to time, just to be nice. Reason I've done that is, I've also been given killer deals from time to time. Just giving a little back I guess.
To the OP, if you can afford the car, buy it. Sounds like you could make some decent money on the deal, even if he want's the $3600 with a blown motor. If the motor is fine, you could probably double your money pretty easily.
I thought it was a nice gesture. Typically, I like to do business with people that aren't looking to screw everyone over just to benefit themself. That creates distrust, and eventually destroys a business.
![Werd](https://ls1tech.com/forums/images/smilies2/werd.gif)
Sounds like a blown head gasket to me. If it's not knocking chances it is fixable. Head gaskets go under boost/n20 easier than piston/rings. Check the coolant for oil and the oil for coolant. Also since it has been sitting you definitely want to get it up to temp to check for cracks/leaks.
I'd buy it and throw the shortblock out of my car in it and put a 6.0 in my personal car and sell it to mod my car with the profits.
Not telling you what to do but what I would do.
If we were to purchase the vehicle, we would fix it up and re-sell it and split the profit. but you guys are right, its not a good idea to go half and half when it comes with certain things.
If you are going in on the car you better get a contract written up and signed by EVERYBODY involved that details the intentions you guys have. Oh yeah and make sure nobody drives it without everybody's approval.
Still not a good idea though. I'd beg the parental units/grandparents for cash to help you make a buck before I went in with friends. Blood is thicker than water and it's not THAT much and you CAN get your money back and then some so I would definitely go that route. Make sure they know your trying to make some money and not another car keep and they can split the money with you.
#32
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Sounds like you need a head set, plugs, head bolts, and a trip to the machine shop to get the heads milled. Whats that... 600?
#35
Alright guys, Ill be finding out tomorrow if this deal will go through for me. If not, i dont mind PM'ing you the guys number... for a smal fee!!!!! ...... just playing, lol.
