How can this be?
An auto simply has lower numbers due to the auto robbing more power than a m6 in power lost through drivetrain efficiency.
If you take equivalent cars with the same engine, both should run the same, but the m6 will dyno higher. The secret to the auto is in the stall and speed in which it shifts at. It'll launch better and shift faster. The m6 will make better use of its power BUT has the difficulty of launching with a clutch (with a fragile rear end no less) and time lost from shifting.
LOL
