General LSX Automobile Discussion Non-technical LSX related topics.
Help!!
Old Apr 6, 2008 | 02:14 AM
BlkBird2000's Avatar
Default Help!!
I didn't do a oil change when I bought the car. I drove it over a thousand miles so far. Well the change oil light came on so the next day I changed it. The light is still on. Should I change it again or does it go away after awhile? It's been on for almost a week.
Old Apr 6, 2008 | 02:43 AM
badjuju342's Avatar
Deranged Rat Fink
Turn your key to the "ON" ( not start) and press the gas pedal three times , it will magically go away.
Old Apr 6, 2008 | 03:09 AM
CRAGER's Avatar
Administrator
owners manual > you
Old Apr 6, 2008 | 06:41 AM
Smoke Panther's Avatar
press and hold the trip button while the car is either running or in the "ON" position...the oil change light should flash a few times, then go away
Old Apr 6, 2008 | 12:47 PM
Shinigami2x4's Avatar
It has to be on the "on" not start postion, and you reset it by holding the trip/odometer stub swich thing and it will blink a few times and go away.
Old Apr 6, 2008 | 09:47 PM
RyderTA's Avatar
Right on the money, I believe it's 15 seconds that you have to hold it too.
Old Apr 6, 2008 | 11:18 PM
Originally Posted by CRAGER
owners manual > you
Who reads the owners manual?? That's why we have this section and the noob section. You coulda helped out and said something that would of helped me. You probably didn't know anyways cause you probably didn't read through the manual either! Owners manual > Craig
Thanks for everyones help.
Old Apr 6, 2008 | 11:28 PM
I read the owners manual, on both my TA and pickup. I also use it to reference my tow/haul weights and options. It also has a nice little section in the back that troubleshoots minor common problems. It also lets you know the type of fluid in the tranny/rear ect. I always figure its worth a flip through if you dont know your vehical well.
badjuju342's Avatar
Deranged Rat Fink
Well , I guess you can do it both ways , I didn't know that. On our '01 , I always did the gas pedal trick and it worked every time. I'll try the odometer trick next time around.
Old Apr 6, 2008 | 11:30 PM
dark ws6's Avatar
Would this work on my 2001 GMC denali?
Old Apr 6, 2008 | 11:47 PM
badjuju342's Avatar
Deranged Rat Fink
Probably , won't hurt anything if you tried both ways
Old Apr 8, 2008 | 01:47 AM
CRAGER's Avatar
Administrator
Thumbs up
lmao, na I've read it before.
So ok, how about this:
> you
hahha
Peace,
Craig.
Old Apr 8, 2008 | 04:48 AM
> you
hahha
Peace,
Craig.
Why search when we have good ole Craig to join in and give such excellent information/advice on the subject?
Oh, and who says peace anymore? hahaha
Old Apr 8, 2008 | 04:50 AM
Oh yea, I actually opened the manual today and got it all how I wanted it. Guess I should of looked at the manual first. But then again, why look at the manual? We have Craig! haha
Old Apr 8, 2008 | 05:00 AM
CRAGER's Avatar
Administrator
Exclamation
Yea why look at a manual that might actually give you some kind of input on a vehicle you drive, or not try a search. Because you're way to damn lazy and want others to tell you or search for you.
This is for you:
..and since this thread is done, this is also for you
Peace,
Craig. (I always sign off that way, deal with it)
