Rubber Transmission Hose?
replaced some worn trans and tq arm mounts a few days ago, and without noticing at the time, a rubber hose line was attached to the tq arm that came out with the arm.
Now I dont know what that hose is or where it goes, anyone know what I am talking about?
I can get pictures if necessary...
I was thinking a trans overflow but that doesnt make much sense for it to be rubber?
it is a vent tube that hooks to the top of the trans. if you run your hand across the top of it you will feel a metal tube that is maybe 2-3" long, that tube connects to it. Its on the flat part of the top, in between the bell housing and the tail.
*****EDIT******
If you look where the yellow strap is, at the top right of that strap you will see the tube, this is on a LT1 4L60E but its pretty much the same. Look in that general area.
*****EDIT******
![](http://i36.photobucket.com/albums/e32/Ntimid8r7/trans.jpg)
thanks for the info
also, forgot to mention, this one has a plastic valve-type split in it?
the trans is working good w/o the tube, i'm assuming its only for if you overfill the transmission?
