how to tell if its a real firehawk?
Location: Your girl's back door giving her the long stroke while you're at work
Found this in the stickies
How to Tell an SS/WS6/Firehawk is Real
SLP made the SS until " " when GM started building them inhouse. ASC did all the WS6 conversions and SLP did all the Firehawks.
im tired of seeing threads asking if my SS/WS6/T/A/Z28 is real. here are a set of instructions on finding out exactly what it is and obtaining legit proof.
1. Take VIN to GM dealership
2. Go to Parts and Service
3. Give them your VIN and ask them for a build sheet and window sticker on your car.
4. if you dont want to pay, ask them to confirm if it is real or not.
SLP/ASC specific cars.
Call SLP or ASC with your VIN and have them verify if it is a true SS/WS6
SLP did the SS and Firehawks
ASC did the T/A's
Phone numbers and addresses:
ASC:
1 ASC Center
Southgate, MI
48195
Phone: 734-285-4911
SLP:
1501 Industrial Way North
Tom River, NJ
08755
Phone: 734-349-2109
Fax: 732-244-0867
https://ls1tech.com/forums/showpost....7&postcount=19
- SS = WU8 RPO Code
- WS6 = WS6 (crafty huh) RPO Code
- Firehawk = WU6 RPO Code
- Differences from WS6 and 'Hawk
Looks and OPTIONS yes, gears no. All LS1 Firebirds wheather they were WS6's or regular T/A or Formulas that were ordered as Autos (A4's) came w/3:23's. All that were ordered as 6-speeds (m6's) came w/3:42's. WS6's, Firehawks, and regular birds wheather T/A or Formula share identical drivetrains an LS1 350 coupled to a M6 or A4 tranny. As far as looks goes? That's in the eye of the beholder. The Firehawks have a little more than looks over the WS6's which is mainly options and rarity. Firehawks came stock w/3" intermediate exhaust w/dual-dual tips. WS6's on the other hand came w/2.5" intermediate exhaust w/single-single exhaust with the exception of the '98 WS6 which had single left side exhaust. Firehawks also came with a slightly different designed 5-spoke wheel which you could order in 2 different finishes: Stock flat aluminum gray, or Option triple-chrome plated (real chrome) not a high polished aluminum like WS6's. Now to the hoods. Firhawk hoods are functional Ram-Airs as well as the heat-extractors (located on top corners of the hood) just a different design. Hawk hoods are more of a composite 1-piece that is designed specifically to fit with the front facia of the Hawk. WS6 hoods are a composite 2-piece hood which is just a regular Firebird hood with 2 air inlets molded to the top, thus giving that 4 nostril look. This hood can be bolted to any regular Formula or T/A bird without any fitting problems. Unlike the Hawk hoods which must be fitted with the slightly different designed front facia of the Hawk. Now, everything I just mentioned to you was standard equipment for Hawks. What really separated the two were the extra SLP options that were available for Hawks which were:
-Firehawk embroidered floor mats
-Bilstein Suspension '99-'02 or 1LE '01-'02
-Specific triple-chrome plated Firehawk wheels
-Lower rear-deck SLP spoiler which were standard on Anniv. Hawks
(HAWKMAN_)
ASC did the T/A's
ASC:
1 ASC Center
Southgate, MI
48195
Phone: 734-285-4911
SLP:
Tom River, NJ
08755
Phone: 734-349-2109
Fax: 732-244-0867
Thats what i was thinking. Wish i knew what mine had in it for gears cuz i wanna change mine to 3.73s but if i already got the 3.23s i don`t know if it be worth it but i don`t even wanna know the cost of doing it even though i`d do it myself i`m sure its not cheap.
Second of all, it's not hard to figure out your gear ration. Next time you're out for a drive keep track of what gear you're in, what speed you're going, and the engine rpm and you could calculate it from that or use one of the online calculators.
ASC did the T/A's
ASC:
1 ASC Center
Southgate, MI
48195
Phone: 734-285-4911
SLP:
Tom River, NJ
08755
Phone: 734-349-2109
Fax: 732-244-0867
- SS = WU8 RPO Code
(HAWKMAN_)
ASC did the T/A's
ASC:
1 ASC Center
Southgate, MI
48195
Phone: 734-285-4911
SLP:
Tom River, NJ
08755
Phone: 734-349-2109
Fax: 732-244-0867
LS1Tech Administrator
Received 1,692 Likes
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
