General LSX Automobile Discussion Non-technical LSX related topics.
Car wont idle after AIR and EGR delete.
Old 08-03-2009, 01:13 PM
billymz28's Avatar
just go to oriellys and get a freeze plug thats all they sell you from texas speed. It worked perfect for my last car.
Old 08-03-2009, 01:19 PM
firstinlastout86's Avatar
Originally Posted by ronald fields
hate to bother yall with my problems, but im havin an issue with idling aswell, i did the EGR AIR delete as well, along with the CATS and rear O2 sensors, my car wount idle at ALL.
i also did the MS3 cam, ported the heads and went with the weiand ls6 aluminum intake
im thinkin it wount idle because im still on a stock tune, but not sure, regardless, it should still idlea some what
Deff the tune...
Old 10-05-2009, 11:15 PM
ls1kbush's Avatar
I agree with this guy. I just got one for my car. Its a rubber 1&3/8 freeze plug that you tighten a nut on the end of and it expands. Cost like 3 bucks.
Old 10-06-2009, 09:39 AM
WSsick's Avatar
sounds like a vac leak. freeze plug will fix it. cheap fix too.
Old 03-25-2010, 11:01 PM
getcha 01's Avatar
Originally Posted by 02Z28LS1
have you checked the throttle body yet? if the blade is sticking open, even partially, that could cause more air to get in = higher idle.
From the picture your wheels look like my 2001 WS6 wheels, but just newer or chrome....are they a copy of the 01-02 WS6 wheel? I bent the lip on my right front rim and from GM they want $1600 for a set with my buddys discount and he is a lead mechanic at the dealer. I found a used set for $900 in the 6 months I've been looking, but they were in worse shape than mine!...for your wheels is the tire size 275 40 R17?....if so how much did you pay for all 4?
Old 03-26-2010, 06:36 AM
pber13's Avatar
if you put an aftermarket cam in, that's why it won't idle. your computer has basically no idea what's going on because the valves are not doing what the computer is used to seeing, so it just barely runs. get it tuned
Quick Reply: Car wont idle after AIR and EGR delete.
