lq9 build done.....for now
2001 m6 z28
well its a 6.0 lq9 out of an 02 escalade
-bottom end-
arp rod bolts
clevite coated bearings
moly rings
ported oil pump
-top end-
stock 317 casting heads ported with a 3 angle valve job
dual gold valve springs
magic stick 3 cam advanced 4 degrees
rollmaster double roller timing chain
ls6 intake
bbk 80mm throttle body
-other-
centerforce dual friction clutch
aluminum driveshaft
k and n intake
80mm slp maf
pacesetter headers
off road y-pipe
magnaflow catback
-suspension-
edelbrock strut tower bar
edelbrock adjustable torque arm
adjustable pan hard bar
bmr tubular k-member
bmr sub-frame connectors
kyb adjustable struts
lowering springs 2" drop front 1 3/4" rear
![](https://i75.photobucket.com/albums/i286/redneckin8805/DSC00920.jpg)
![](https://i75.photobucket.com/albums/i286/redneckin8805/DSC00919.jpg)
![](https://i75.photobucket.com/albums/i286/redneckin8805/DSC00908.jpg)
(oil pressure guage is inside the car now lol)
-bottom end-
arp rod bolts
moly rings
ported oil pump
-top end-
ls6 intake
-other-
aluminum driveshaft
k and n intake
80mm slp maf
pacesetter headers
off road y-pipe
magnaflow catback
-suspension-
![](https://i75.photobucket.com/albums/i286/redneckin8805/th_MOV00918.jpg)
