General LSX Automobile Discussion Non-technical LSX related topics.
Quick Help!!!
Old Aug 4, 2008 | 08:41 PM
lonsr's Avatar
Default Quick Help!!!
where is the signal light flasher located on a 99 trans am? I am looking under the panel underneath the steering column but i cant find it. I need to replace it. thanks
Old Aug 4, 2008 | 08:54 PM
foreverzero's Avatar
its hard to say, i think its to the upper right if your looking under...easiest way is to go to a part store and buy it and look under the column and match it up
Old Aug 4, 2008 | 08:59 PM
redls1bird's Avatar
Unless the parts store guy gives you the wrong one....
Why do you think it needs to be replaced?
Old Aug 4, 2008 | 09:10 PM
lonsr's Avatar
I got it. thanks guys. To be exact the flasher is on the right side under the steering column. It has a clip that holds it to the metal panel under the dash. has a red connector for the two prong flasher. I just changed mine and it worked. now I have signals !!!!
Old Aug 4, 2008 | 09:11 PM
frogger13's Avatar
Take off lower and upper panels on drivers side.Its right behind your hvac ***** on a clip,right behind the fan ****.
emergency flasher is on the topside of the steering column.
