17" wheels, speedometer off?
So I went from the 16" twisties with 245/50/16 tires to 275/40/17's. According to the highway sign distance to the gas station, the trip odometer is still accurate, and I still do 60mph at 2k rpm with the 3.23 gears, but it seems like the trip odo is ticking fast. Is it just in my head?
It's almost exactly the same.
245 size -
Overall Diameter: 25.64 in 651.25 mm
Actual Speed: 60 mph 100 km/h
275 size -
Overall Diameter: 25.66 in 651.76 mm
Speedometer1: 59.9 mph 99.9 km/h
Speedometer Difference: - Speedometer Difference: 0.074% too slow
Diameter Difference: - Diameter Difference: 0.08%
Not worth writing home about.
245 size -
275 size -
http://www.miata.net/garage/tirecalc.html
http://www.onlineconversion.com/bigger_tires.htm
you can use those later on if you need to see how much of a change it will make
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
