Fan direction Control
Check for a small vac line that runs to back of intake on passenger side it hooks up under map sensor will be a hard plastic tubing about a 1/8 inch dia. could have come loose or broken.
You have a turbo right?
The servo actuators that control the vents operate on engine vacuum--put a turbo on the car and you have positive pressure in your intake.
