General LSX Automobile Discussion Non-technical LSX related topics.
2008 Corvette
Old Sep 30, 2008 | 06:36 PM
Doubledip's Avatar
Default 2008 Corvette
Hi guys, very simple and basic question to start with.. I am from the land downunder and would like to know if the 2008 corvette has a shift light in the dash?
Old Sep 30, 2008 | 10:40 PM
sslateron's Avatar
If it doesn't install one! F T W!
Old Sep 30, 2008 | 11:25 PM
Doubledip05's Avatar
i wanted to know if they have , cause i am looking for a particular pin in the ecu to control something..
so once again do they have/come with one?
Old Sep 30, 2008 | 11:38 PM
wht01ws6ta's Avatar
I think they have CAGS but not sure about a shift light to accompany that but more interestingly WHY are you posting under two profiles (assuming it's the same person)?
Old Sep 30, 2008 | 11:53 PM
aothepresident's Avatar
^ "Doubledip"
Old Oct 1, 2008 | 12:10 AM
wht01ws6ta's Avatar
Originally Posted by aothepresident
^ "Doubledip"
He's doubledipping
Old Oct 1, 2008 | 12:14 AM
sslateron's Avatar
Originally Posted by wht01ws6ta
He's doubledipping
No double dipping allowed!
Old Oct 1, 2008 | 09:22 AM
Dark SS's Avatar
The 2007 does not and I haven't read anywhere that it was added in 2008. I'm pretty sure there is no shift light.
Old Oct 1, 2008 | 03:25 PM
sslateron's Avatar
Get the HUD, and no need for a shift light.
Old Oct 1, 2008 | 03:43 PM
Doubledip's Avatar
the double posting bit "Doubledipping" my mistake.. another fourm i couldnt use my normal login so used that second one.. for the reason i logged on here with ... i have no idea. if the Moderators could get rid of the doubledip05 thats fine.. i dont want to use that one...
as for the question - in Australia we use alot of serial data between the ECU and insturments but in the US you guys still use a lot of direct feeds 1 to 1 for signals i.e. Tacho , Speedo and so forth.. i wanted to know if the corvette (or something similar iwth an E38 ECU) used a shift light and then find what pin controls it...
Old Oct 6, 2008 | 11:37 AM
question's Avatar
You can tap into the tach pin on the ecu if thats what your trying to do...kinda like installing a shift light..
Old Oct 6, 2008 | 02:46 PM
Doubledip's Avatar
thanks for the reply - but as cant do that.. there is no tacho wire.. all the data is travelling alont the serial data on a E38 ECU in a late model holden in australia.... the pin is free but it is useless to use as the ECU is setup to use serial not crank...
