Sponsored by: CARiD
battery gauge ??
Old Oct 10, 2008 | 08:36 PM
christrusler's Avatar
Default battery gauge ??
I have a 2000 Z28, i've replaced the alternator, and battery this week. Here's what's happening..
My battery meter will sometimes be right in the middle showing normal charge, and then sometimes for no reason i can think of it goes in the red, dash lights dim down like it's low on power, then for no reason it will go back up after a while. Revving the engine doesn't bring the gauge back up. New alt, and battery this week, and still having problems.
I've checked the wires running from alt to battery and they're fine.
Any ideas???
Old Oct 10, 2008 | 10:37 PM
*98TransAm*'s Avatar
Any ideas???
so you double checked to make sure all the wires are tight? at the battery and alternator. also check for corrosion.
Old Oct 10, 2008 | 11:30 PM
LiT1_up's Avatar
Any corrison at the terminal ends? How about where the negative cable is attached to the block?
Old Oct 10, 2008 | 11:44 PM
bamalt1's Avatar
Sounds like a loose ground. Check all your wires.
Old Oct 11, 2008 | 09:04 AM
samson_420's Avatar
A lot of times you can have corrosion inside the wires, that you will not see.
Old Oct 13, 2008 | 08:36 PM
i've checked everything, all wires are tight, no corrosion, can't figure it out
Old Oct 13, 2008 | 08:52 PM
sweetbmxrider's Avatar
another bad alternator? really sounds like a ground is loosening up on you.
Old Oct 13, 2008 | 09:46 PM
coryprine's Avatar
is it a new or remanufactured alt.? i went thru the same issue with 3 remanned alternators and inally gave up and bought a new one from the stealership... no problems since that
Old Oct 14, 2008 | 09:37 PM
it's a brand new, both of them i've bought were brand new
