Sponsored by: CARiD
Headlight problem
Old Oct 11, 2008 | 02:24 AM
Proofz's Avatar
Default Headlight problem
My passenger side headlight bulb went out, I replaced it, later the same day it goes out again! Well I bought another bulb thinking the first one was busted or w/e and now the light wont come on at all? Is this a common problem? Where do I even start with this?
Old Oct 11, 2008 | 07:45 PM
Proofz's Avatar
ttttt help appreciated!
Old Oct 11, 2008 | 09:01 PM
lovin myls1's Avatar
Unplug connector from other side and plug into your new bulbs and see if they work.Or, if you can, check voltage at connector on headlight that won't work.Let us know the results.
Old Oct 12, 2008 | 08:00 AM
Proofz's Avatar
What do you mean unplug the connector from the other side? Like theres the part that connects into the bulb but what else? Do you mean plug the drivers side plug into the headlight to make sure it works?
Old Oct 12, 2008 | 08:19 AM
Yes,that will tell you if the new bulbs are good or if they went bad.If the new bulbs work on the drivers side and not on the passanger side,you must of lost voltage supply at the passanger plug.Do you have a meter to confirm that?
Old Oct 14, 2008 | 02:26 AM
Proofz's Avatar
turns out the ground wire was severed connecting to the headlight connector thing!
Old Oct 14, 2008 | 04:59 AM
Glad you found it!
