Sponsored by: CARiD
Odd rattle
Old Oct 13, 2008 | 05:19 PM
Nick_Rapitis's Avatar
Default Odd rattle
theres a weird noise from time to time when the cars in gear and im on the break i hear a sort of rattle but ive been under there a thousand times and cannot find anywhere the exhaust is hitting...i;ve loosened everything and moved it around to make sure theres clearance but i still get that damn noise every now and then...it even does it sometimes while im going but far less often than when im stopped on the break...any suggestions?
Old Oct 14, 2008 | 12:04 AM
Teakwo23's Avatar
My car does the same thing? I have a 2001 Silver SS. It drives me nuts man. I can't figure it out either. Let me know if you figure anything out.
Old Oct 14, 2008 | 12:22 AM
09CPTN's Avatar
Same here. I bet it's my y-pipe. No question.
Old Oct 14, 2008 | 07:46 AM
what about your y pipe?
Old Oct 14, 2008 | 12:12 PM
TrakJunky's Avatar
Might be your 02 shields.. tap around the 02's with a rubber mallet. There is a little metal piece that shields them on the inside of the pipe. If its rattling you can try to right stuff them in. I had a rattle when declerating or when letting the revs fall to idle at around 2K RPM.
Old Oct 14, 2008 | 12:24 PM
so how would i fix that? new o2s?
Old Oct 14, 2008 | 06:04 PM
Teakwo23's Avatar
Ill try that.
Old Oct 14, 2008 | 08:35 PM
my noise if def from the back of the car...
Old Oct 14, 2008 | 08:39 PM
and usually when the car is cold...
Old Oct 14, 2008 | 08:53 PM
ebaker's Avatar
same here man i cant figure it out either. im hopefully going to take it to a friends house and put it up on the car lift and see if we can find out what the heck is going on. if i find anything out ill let you know.
Old Oct 23, 2008 | 11:50 PM
Teakwo23's Avatar
Finally found out the problem. It was my cat. I took it to the dealer and had it replaced under warrenty. No more noise!
Old Oct 24, 2008 | 01:23 AM
let me guess passenger side cat? mine went bad too, already replaced that...i think the noise i had was the passenger side hanger...it has a foam/rubber part but the metal holding it to the car and the hanger were hitting from time to time....just pushed it out a little and no more worries...yet
Old Oct 25, 2008 | 05:01 PM
Teakwo23's Avatar
Yup Passenger side Cat! Did you get it replaced for free? How many miles on your car? I have almost 60,000.
Old Oct 25, 2008 | 08:27 PM
as far as replacing the cat...i would go with the catco y pipe i think its part number 9033...it doesnt have the pinched driver side pipe...very good investment!
