door making popping sound
Hey guys
recently my drivers side door has been making a loud *POP* when ever i open the door. For some reason it gets worse in colder weather...
it seems as if it's catching on the front fender.
Can anyone help me out with this?
thank you
Craig
thank you
Craig
It probably is catching. Stand outside of the car and open and shut the door a few times and watch to see if it's catching. May need to adjust the fender or maybe the door is sagging a bit...hinge?
Catching near the bottom, as in the bottom of the front fender or the bottom of the door (i.e. hitting the rocker??) First off, determine what the problem is and what's causing the catch. Look at the alignment of the fender compared to the hood and the front clip. If they look like they are aligned, it's probably not the fender that is the problem, but that the door is. In this case, it's probably the hinge that may need replacing. Again, start looking more closely at what's going on and what would be the most likely cause of the door catching. Perhaps some pics would be good...
