Sponsored by: CARiD
Post Seafoam maintenance...
Old Oct 26, 2008 | 12:20 PM
LS1CALIBOY's Avatar
Default Post Seafoam maintenance...
So last week I seafoamed my car and this week I'm gonna change the oil and filter but i was wonderin if i could change the plugs now as well and then the wires later because money is tight and i cant do it all at once right now?
Old Oct 26, 2008 | 12:41 PM
km346's Avatar
As long as you don't damage the wires trying to get them off the old plugs you should be fine...
Old Oct 26, 2008 | 12:55 PM
texasglock23's Avatar
You should be fine. Just make sure to use di-electric grease on the cable and anti-seize on the plugs.
Old Oct 26, 2008 | 01:30 PM
LS1CALIBOY's Avatar
Thanx guys...I just wasn't sure if it was ok to run new plugs with old wires...I'll go ahead and do that then...
Old Oct 28, 2008 | 05:28 PM
ZeroFear's Avatar
I think if you do a search you can find the stock wires for pretty cheap. I know after -market wires are like $50 bucks, but I'm pretty sure the stock ones can be had from a vendor for cheap.
