Sponsored by: CARiD
Possible Blown Head Gasket
Old Oct 27, 2008 | 05:37 PM
sleeper-Z's Avatar
Default Possible Blown Head Gasket
I have what I think is a blown head gasket, but before I spend loads on replacing them, is there anyway to check if it's just an intake leak?
I've got a 355 with 8# vortech, blower cam and the heads had to be decked and re done once before. Cometic MLS gaskets were used.
Any help would be highly appreciated!
Old Oct 27, 2008 | 05:42 PM
conan's Avatar
Do you have coolant in the oil? Do you have white smoke comming out of the exhaust?
Coolant running down the block under the heads?
Old Oct 27, 2008 | 07:50 PM
sleeper-Z's Avatar
I'll have to check for the coolant on the block but I do know that there's oil in the coolant and a very faint sign of white smoke in the exhaust.
Old Oct 27, 2008 | 08:05 PM
618HAWK's Avatar
A compression check would not hurt.
Old Oct 27, 2008 | 11:06 PM
conan's Avatar
If coolant and oil are mixing you got problems. Drain the oil and if itlooks like chocolate milk coolant is leaking. Like 618hawk said do a compression test that might give you a idea of what cylinder to look at first and then i would pull the heads.
Old Oct 28, 2008 | 06:50 PM
sleeper-Z's Avatar
I couldn't find any coolant on the engine block. But if there's oil in the coolant doesn't that mean that there has to be coolant in the oil? And also I'm smelling a little bit of burnt or hot oil thru my interior vents, and I don't think I spilled any oil on the engine. The oil level is good right now, but I seem to loose coolant pretty quickly when I'm driving it. Also, this could just be because of my cam or whatever, but I lose about a quart of oil per tank of gas.
This this help at all? I'll get that compression check done soon.
Old Oct 28, 2008 | 07:42 PM
conan's Avatar
I wouldn't drive the car any more! If there is oil in the coolant you have a problem. You could hydrolock the engine and then the hole thing is junk. Do a compression test and then pull the heads.
