Turn Signal Electrical Problem, wtf?
I went to work on my turn signal today and found that it will not blink at all (tail light bulb is NOT burnt out, so its not that). So I tried the quick fix, filled the socket with bulb grease. No dice.
When I turn my headlights on (switch all the way to the right) both passenger and driver side DRLs come on. Great! But not so fast...clicking my turn signal, the bulb goes off and does not blink. Dashboard has a solid green arrow indicating something is screwy.
So what is going on here...how do I fix this, its really annoying me that it turns on with the headlights but will not click or blink with the turn signal. I was tempted to mess around with the wires, but my total lack of electrical experience caused me to second guess that seeing as I didn't want to electrocute myself or something stupid. Can anyone help me out here?!
It keeps blowing because of moisture getting in there. There are several ways to fix it. You can do the DRL mod listed above (do a search to find more) but you drill a small hole in the BOTTOM of the light housing so the water will drain out.
And/Or, what i did and prefer is sealing the system. Use plenty of die-electric grease in the socket and right before placing the socket and bulb in the housing wipe the bulbs to get the oil and grease from your fingers off (dont know if this actually helps, but ive heard it can reduce the tempature of the bulb). There are supposed to be rubber pieces on the blinker light sockets that are supposed to seal it to the housing. Sometimes these are missing, so water gets in. If you dont have them, make something to replace them or try and buy some. You can probably get something at GM. On top of this i applied RTV (gasket maker)... on both sides of the rubber piece, and i used quite a bit to seal it. I pretty much had the additude that i didnt want to do it again, lol. So i applied alot and then put the socket and bulb in (dont forget to wipe), cleaned up the excess RTV and was done. I used to go through 3-4 bulbs a year, its been a year since ive done it and havent replace a single one (knock on wood).
Went to change the socket after cleaning the connections.
Gauge lights and fog lights no longer come on when I turn the headlight switch to center or all the way on (full right) -- DRL/Turn signals actually turn off when its on any other position other than all off (full left). Fog lights, turn signal flash when I press the lock and unlock buttons on my wireless keychain. The SES light was on before this because I needed to change my oil but now it no longer shows up.
Whats goin on here?! All I did was follow the turn signal socket change-out directions that you can read here: http://www.ls2.com/forums/showthread...threadid=15143
Any thoughts?
