i just put in NGK TR-5 spark plugs. i'm now reading they are shit. what to do?
Old 11-04-2008, 01:00 AM
Nickstock98t/a's Avatar
Default i just put in NGK TR-5 spark plugs. i'm now reading they are ****. what to do?
i spent hours!! only to come online later and find out tr-5's are not the way to go. what should i do?
Old 11-04-2008, 01:05 AM
JMBLOWNWS6's Avatar
LOL I ran TR-5's in my NA setup without a problem. Went to a 6 when I sent with boost. I dont know who is telling you that but they ran fine in my car and the other 100 cars Ive put them in.
Old 11-04-2008, 01:26 AM
should i notice better throttle response with tr-5?
actually ive only done 4 on the drivers side so far.
should i just get tr-55's and put em on my remaining 4?
how much do TR-55's go for?
THANKS
Old 11-04-2008, 01:30 AM
JMBLOWNWS6's Avatar
Sorry I didnt type this right. I meant tr-55's. Which is what I think you are talking about.
Old 11-04-2008, 01:32 AM
i'm talking about ngk tr-5's is what i got on.
Old 11-04-2008, 02:07 AM
hashtagBMW
Speed Density's Avatar
So your running 4 NGK's and 4 other plugs?
Your not going to feel any power gains, the TR5's are a good plug, finish your install and leave them be.
Old 11-04-2008, 02:12 AM
DevilDougWS6's Avatar
so you spent HOURS installing JUST the driver side?
tow your car to nearest shop and let them do the work. you are not going to notice any power gain from ANY plugs. ALL plugs deliver the same amount of energy, and the stock ignition system is more than sufficient for msot power applications. get tr55s and be done with it.
Old 11-04-2008, 02:15 AM
F it. im just gonna finish up with TR-5's for the remaining 4 on the passenger side.
what should i expect after completing the 8th Tr-5?
better mpg?
Old 11-04-2008, 02:19 AM
yes i spent hours. this is my first. plus im working with tools i can at my aunts.
i didnt unplug ****. just the plugs and wires. no ac, blah stuff.
i feel like next time i do the the driver side it should take me 15 mins tops if im not too herbally infusing myself this time around.
Old 11-04-2008, 04:00 AM
WhitePhoenix99's Avatar
Wait so is there a difference between the tr5s and tr55s or is it the same plug being talked about?
Old 11-04-2008, 04:06 AM
tr55s are a different plug. they would be a better choice for a mostly stock ls1. i run tr6s because of my cam.
the passenger side is a nightmare compared to the driver side, just so you know.
you wont notice any power gain your engine will just run better. mpg gain will be negligible. +-1-2 mpg
btw: drugs and cars......dont mix, telling us on the internet does not make you look cool.
Old 11-04-2008, 04:15 AM
sawedoff's Avatar
It really makes it easier to change plugs if you'll remove the coil packs on the valve cover on the passenger side. That last cylinder #8 plug is a bitch to get out because of the leverage problems in getting your hand in there to where you can get good grip to loosen the plug out. These cars are front mounted mid engined cars.
In my case I used Bosch Platinum +4's and never had a problem. Like most have said, you really won't notice a big difference unless something else is really out of whack. I did notice better throttle response in going to these particular Bosch pieces from the AC plugs and the NGK.
Old 11-04-2008, 09:44 AM
LS6427's Avatar
Dude.....don't use TR-5's in a stock LSx.
TR-55's are what you should use.
I know some peoples engines run ok with TR-5 and TR-6 plugs. When my engine was bone stock it ran like **** with TR-6 plugs that some ******* at Pep Boys told me to use 9 years ago when I was still stock "and didn't know what I do today about our engines".
TR-55's ONLY in a stock LSx.
And once you figure out the correct tools to use for changing plugs, Passenger side (the harder side) will take you 20-25 minutes total, the drivers side will take about 15 minutes total.
Old 11-04-2008, 08:40 PM
how did it run like ****? what was it doing?
i have a 1998 which makes it harder to follow the instructions/picture instructions on www.INSTALLUNIVERSITY.com for the passenger side coil pack rail bolts
since you have a 1998 as well can you give me tips on that? im really starting to beat myself up
im starting to give up and just leave the passenger side alone. i already took the two 10mm bolts from the air pipe manifold on the passenger side.
this really sucks
im stuck
Old 11-05-2008, 09:11 PM
btw those ngk tr-5's on my driver side were 40mm out of the box
but i gapped hem at 60 with the tool because thats what it says on our engine bay
i then proceeded to talk to some guys at the local shop and they said i should of left it at 40
but they said if all is running fine i should be fine. all seems fine. what do you think?
Old 11-05-2008, 09:24 PM
pHEnomIC's Avatar
I dont think they are ****, just get the gap right.
Old 11-05-2008, 09:27 PM
its already in there though. i gapped it at 60. tr-5's are 40 out of the box.
should that be a problem?
Old 11-05-2008, 10:15 PM
samson_420's Avatar
Well, well, well - - - -
60 is a bit much, but since you done only one side it should equal out between the other 4.
Old 11-05-2008, 11:42 PM
pHEnomIC's Avatar
Wait whoa whoa whoa, dont ever run different plugs in different cylinders, that is asking for it, your fueling is gonna be different in those cylinders.
Quick Reply: i just put in NGK TR-5 spark plugs. i'm now reading they are shit. what to do?
