Sponsored by: CARiD
wiring
Old Nov 9, 2008 | 04:29 PM
therobman's Avatar
Default wiring
i finished my m6 swap or so i thought well finnally blead the clucth and when i go to start it it wont crank, and the securty light comes on, on the dash. when it goes away i try it again same thing. i know it not the neutral saftey switch because after this happened i tore it apart and just had them wired together any suggestions ? also i took out my steering column to do the swap but im positive i pluged everything back in i figure its the vats cause the light stays on so anyone know what connector is for the vats on the steering column
