leaking t-tops
leaking t-tops
Is it common for the driver side T-top to leak? If it is a steady rain and I am on the road it will leak about the middle of the window. I have had my window tinted, could that be the problem? Please advise.
Re: leaking t-tops
Neither of mine leak....but then again I never drive in the rain. However when I wash the car they never leak. If it's still under warranty take it to the dealer.
Re: leaking t-tops
I had a Corvette that leaked badly, so when it came time to order my Camaro I chose a fixed roof coupe.
The owner's manual has a specific proceedure for installing your t-tops. Give it a try, but if it doesn't cure the problem take it to the dealer. Hopefully your still under warranty.
Good Luck!
Good Luck!
Re: leaking t-tops
Depends on how old your car is, the condition of the door seal, and if your twisting the body of your car.
quick tips
sub-frame connectors,this will stop your t-tops from shifting.
do not armor all your seals. this makes the rubber real slippery, and water finds it's way between the window and seal.
of course these are just some of the possibilities. I hope this helps good luck
quick tips
Re: leaking t-tops
I've got a 98 WS6 and the drivers side leaks - not bad, but enough to tick you off. Interesting about how not taking the tops out can cause a leak due to compression. I rarely take them out. That could explain it. Anyone else?
Re: leaking t-tops
Re: leaking t-tops
Same drip, same place here also since new and never had my windows tinted. Dealer replaced weather stripping under warranty, helped a little. I adjusted the door striker in a little which made the door close tighter, that helped some also. If the hard top was an option on the Trans Am I would have jumped on it. T-tops suck.
Re: leaking t-tops
Mine leak...so did my '89. The "non-leaking" T-tops are a seperate option box in the order sheet and cost extra. I saw a survey of GM options and they listed T-tops as the most popular/most troubling option. It seems that they've always leaked and will always leak....or it is likely. My passengers side drips on occasion and they both leak at the carwash (and I'm careful not to spray the glass/t-top area much at all). I never bothered to take mine back to the dealer...I didn't figure it would help. And, FWIW, I have mine out all the time....daily if I can.
Re: leaking t-tops
Damn it. I just thought I had a shitty T-top. Mine leaks on my drivers right on to my arm as well. It drives me crazy! Thank god it is not a daily driver! I have only driven it in the rain a handfull of times. T-tops, but I do love them in nice weather!
Re: leaking t-tops
My T-Tops do not leak. They do not leak in the car wash. They do not leak in the rain. I wanted to specifically buy a car with t-tops as they are better than a convertible (safer, lighter, cheaper insurance, and looks better than a covertible roof when up). I love them and have them out more than in (helps to live in a place where its >60 deg in winter).
I was told by a guy who has had t-tops dating back to the 70's on his cars about keeping them off or at least unlatching them at night to save the rubber seals to keep them from leaking. Someone posted a similar comment on either this forum or the "Other" one last year who seemed very knowledgable on the subject.
Re: leaking t-tops
I forgot to mention, working in Dielectric Silicone Grease (GM Part No. 12345579 or equivalent) in the rubber seals around the t-top has solved many leaks for people.
Re: leaking t-tops
mine used to leak bad in my v6, but the ones i have now aren't bad, still though, when i use the hose im careful, cuz it will drip in there, sfc may stop this, I think it has somthing to do with the unibody twisting and eventually not sitting as it was when new, i may be wrong, but who knows??
Re: leaking t-tops
Anyone get that annoying squeek or rattle coming from the drivers side T-top? My g/f's V6 Firebird has that problem really bad and its annoying as hell. I just bought an '01 SS w/ T-tops and since I've taken them off and put them back on its starting to rattle now over bumps. Passenger side doesn't do it though...weird.
Re: leaking t-tops
Mines does that drip thing and only on the driver side. Grease thing sound weird but could not hurt. It did not do it when it was new but unfortunitly my car ahs seen two winters and I am sure that has something to do with it.
