Sponsored by: CARiD
No Cluster lights?
Old Nov 13, 2008 | 09:32 PM
Pro52R's Avatar
Default No Cluster lights?
Hey Guys,
I did a 98 V6 to LS1 conversion.
Ok, the car no longer contains anything 98. It is all 00+ spec. Wiring,pcm,etc . The car is literly a 2000 with 98 Body
Well the BCM is 98.
I bought a 99 Trans Am gauge cluster used. Well its not lighting up. All the gauges are working and everything seems to be fine,but no lights when I turn the headlight ****.
Anyone know? Or did I just somehow blow all the lights at once? (no i haven't checked them yet, but will)
Old Nov 13, 2008 | 09:46 PM
samson_420's Avatar
If you are this deep into a conversion you could always route a different power source to the cluster.
Or of course start checking fuses and trying to shoot down the circuit.
Does the Odometer work along with the trip?
Old Nov 14, 2008 | 12:23 AM
Pro52R's Avatar
The cluster works 100% except for it lighting up w/ the headlights on.
I've swapped out the ENTIRE wiring from the WHOLE car for 2000/2001 wiring from a Z28
