Sponsored by: CARiD
HELP Security light. No start.
Old Nov 16, 2008 | 04:12 PM
AbramM's Avatar
Default HELP Security light. No start.
My camaro was running fine that day then i go get in it and it wont crank or anything. Noticed the Security light was on and i cannot for the life of me find out how to get it off and running again. I have left the key on accessory for ten minutes and still nothing. Then i was told t unhook negative battery cable for ten minutes OBD2.
Old Nov 16, 2008 | 04:43 PM
ruquick02ls1's Avatar
same thing happened to me, I had to pull the steering wheel off and the ignition out and the little white wire was broken. I solder them back together and all good now.
Old Nov 16, 2008 | 08:26 PM
92 silverado's Avatar
must be that time of year cause that happened to me yesterday and another guy that owns a camaro. after much diagnosis and the car turning over and not starting i found out my vats module is bad. crank it for a bit and check your codes. could be a p016XX code (anti theft code)
Old Nov 17, 2008 | 07:57 AM
bboyferal's Avatar
HA, this JUST happened to both my TA's almost simultaneously with a recent temperature drop. I was really lucky though. I cleaned out the cylinder and the keys themselves and they work fine now.
Old Nov 17, 2008 | 07:59 AM
OUTLAWZ RACING's Avatar
Happen to me all i did was put the key in and turnd it forward and waited for the light to turn off and it work for me.
Old Nov 17, 2008 | 08:36 PM
AbramM's Avatar
How did you go about cleaning it?
Old Nov 17, 2008 | 09:17 PM
formuhawk99's Avatar
Same problem = BCM. Had it replaced and have never had the problem again.
Old Nov 17, 2008 | 09:18 PM
OD4gen's Avatar
Try cleaning the key with a pencil eraser. I've heard of also using alcohol. Mine started doing that and i cleaned the key with the eraser and it's been fine since. That might not be the problem but i would try that first.
Old Nov 17, 2008 | 09:46 PM
samson_420's Avatar
Bypass the VATS, and install a kill switch.
Old Nov 18, 2008 | 02:25 AM
Snowman2K1's Avatar
light turned on exactly last year on my car... light has always been on since, but my car has always turned on... i tried everything to get rid of it than finally gave up..
Old Nov 18, 2008 | 07:41 AM
bboyferal's Avatar
I used alcohol on the key and a keyboard duster (spray can) into the ignition cylinder...
Since that day, I **** a mini-brick every morning starting the car for work, wondering if it's going to be the day the VATS finally screws me.
*knocks on wood*
Old Nov 18, 2008 | 12:57 PM
sbpower72's Avatar
Old Nov 19, 2008 | 09:35 PM
futuref-body's Avatar
always use to happen to me-dont no why it stopped. i dont no if this is how you are suppose to do it but every time my car wouldnt crank and i saw the security light come on i would get out, lock the car, then wait 2-3 minutes for the light to turn off. i would clean my key while waiting just to make sure-get in and it would crank right up.
