headlamp motor problems... this is weird!!
headlamp motor problems...this is weird!!!! help me out!!!
The other night, i turned my headlights off and they went down but the drivers motor kept running!!
THEN when i locked the car with the key fob, they popped up and down and the motor ran again for a few seconds. What in hell could cause that?
I'm gonna try replacing the switch in the dash tonight.....but i ALSO noticed that if you turn on the parking lights...the lamps pop up but dont come on.
this is weird.
this is weird.
Copy & Paste Moderator
Re: headlamp motor problems...this is weird!!!! help me out!!!
Hey i just want to let you know that u dont really need to use the directions given on that site....they are showing a older model firebird/camaro....if u have the newer one....98-02 u can do it much easier(I just had to do it)....use the manul raise **** and raise the light...then look at the lever that raises the light...you will see that the joint goeses to a a small axel from the motor...it is held on with a bolt that you need to remove...then u have to pull the joint off...let me tell you its nearly impossible...even with liquid wrench its tough....then use the manual **** to turn the motor ****....it goes slow but make sure you watch the axel that held the joint...that is what must be rotated 180 degrees....then put it back together lower the light and it will electronically rebalance
this is weird.
this is weird.
Here is a site that will show you how to attempt the 180 swap or he sells some metal gears that wont strip.
Hope it helps. It helped me. Just be ready to spend some time on it though if its your first time.
http://www.projecttransam.com/
Hey Jabber....
This thread is 2 years old.
BTW, there is also a sticky in the "Pontiac Firebird 1967-2002" section:
https://ls1tech.com/forums/pontiac-firebird-1967-2002/177470-firebird-headlights-all-comments-questions-regarding-headlights-go-here.html
Originally Posted by VIP1
Hey Jabber....
https://ls1tech.com/forums/showthread.php?t=177470
wow i need to stop posting this late at night.... i'm not even sure how that happened....
