Sponsored by: CARiD
Engine cooling fans shut off???
Old Nov 23, 2008 | 07:47 PM
The_Wretched's Avatar
Default Engine cooling fans shut off???
A few times this week after turning off my car the fans are still going. They don't turn off for like 2 min. They're pretty loud. I've never noticed them before.
Is that normal or is something off?
Old Nov 23, 2008 | 08:25 PM
samson_420's Avatar
Depending on the running temperature. . . I had mine do that before, but only when it was real hot out.
Old Nov 23, 2008 | 08:31 PM
9000th01ss's Avatar
Stock programming makes the fans stay on (even with the engine shut off) for 150 seconds if the coolant temp goes above 235 degrees.
Maybe it's running hot.
I've seen 230 degrees on hptuners scanner when the dash gauge read 210.
At 196 my dash gauge reads right under 210, not very accurate.
Old Nov 23, 2008 | 08:48 PM
Sarge91's Avatar
i know this isnt on subject, but my fans have never came on while the car is off.
Old Nov 23, 2008 | 10:07 PM
9000th01ss's Avatar
These are stock settings.
Old Nov 24, 2008 | 09:32 AM
2001NBMZ28's Avatar
Is that ignition off disable temp stock setting correct? PCM doesn't even command the high speed on until 234 running. My helms says key off 284 and approx 3 minute run time. Not saying you're wrong, just wondering.
Old Nov 24, 2008 | 07:51 PM
new issue... while stopped at a red light my temp went up to about 230... then I started to drive it went down to 190.... wtf???
do you think it's my thermostat??
