Turn lights
I tried putting in a new fuse in the #2 TURN B/U slot, but that did nothing. That is about the limit of my car knowledge sadly enough. Any other easy checks for potential fixes without spending more than a few dollars?
Been like this for a while now, and I've grown tired of looking like an *** at uncontrolled left turns and changing lanes on the busy cali freeways.
I am not 100% sure about your 01,but on my 95 the turn signal flasher will be under the steering wheel/column,on the right side of the column,kind of behind the radio area.
Remove the panel under the steering wheel (just a couple screws).You should be able to reach it and swap it out.It will be a cylinder looking object with a 2 prong connector.Not to be confused with the hazard flasher,which will be on the left side of the steering column.
If that doesn't work then check all your outside bulbs.One of those going out have been known to cause turn signal gremlins on these cars.
Anyone know how to check the lever?
Try this sticky.... sounds like its the flasher....its about $8 bucks at auto zone. It's under the steering wheel on the right side. U have to remove the kick panel , you wont see it just the clip that it's on.
